Received email from Van’s—said not to worry about the edge distance—there is no way to get a minimum edge distance at that location. Marked 404/405 ribs with center line after they were fluted. Clamped ribs back to skeleton, drilled holes in 405 rib to 606 spar. Wobbled one hole (drill bit was dull). May need an AD5 rivet in that location.
