Brief Description: Intersection fairings-7, r. wing tip primer
I sanded the intersection fairing some more, then shot a coat of sanding primer on them. They still need some more work—fiberglass work is the gift that keeps on giving—FOREVER! I also shot a couple of coats of sanding primer on the leading edge of the right wing tip. This was the area where I added some micro to match up the tip and the wing. After the sanding primer dried and was lightly sanded, I shot some primer on it. I need to look at it in the sunlight, but it may be close to done. Also, in anticipation of receiving the Crow belts, I reamed all of the attach points to ¼” for a nice fit of the bolts-should have done this a long time ago, but somehow it got skipped.
