Today was “torque wing bolts” day. I started with the large bolts (500 in./lbs) torquing one upper then one lower, then one upper and the final lower. Did this for both sides. Took a short break and torqued the smaller bolts (70 in./lbs) alternating between upper and lower as I moved along. I applied some torque seal to all bolts. So, all 20 wing bolts are in and torqued. Feels good (except for my back) to be done with wing bolts.
