Steve & Nancy Riffe
Date:  8-15-2016
Number of Hours:  3.00
Brief Description:  Cowl work-7
No pics tonight. I first cleaned the lower cowl with compressed air and acetone. Then, I mixed up another batch of micro and applied to the right side of the cowl. There were also a couple of small areas on the left side which I filled. I set this aside and began sanding on the upper cowl. I had previously sanded, applied resin, sanded and shot two coats of sanding primer on the upper. Well, it still had many areas of grain showing, so today I sanded all of the sanding primer off. Next up is to apply more resin and maybe some micro to see if I can get the grain filled.
