I almost finished up all of the nutplate attachments for the right wing today. I squeezed in NAS 1097 rivets to secure the nutplates from the spar forward—all except one right next to the spar. I’m waiting on some MS21053-L03 single lug nutplates from ACS. Then I turned to the aft upper fairing attachments. Squeezed in all rivets for these nutplates also. I wanted to cut the slot in the T-405 fuel tank tab while I had the wing propped up in the cradle. I drew a couple of parallel lines, clamped on my steel “fence” and cut the slot with my dremel, followed by filing and finally with some fine grit paper.
