Part 1 of 2. I was able to clean up the corners of the windscreen where overspray had bled under the tape which had partially pulled away in the heat. I used a q-tip with some “Goo-Gone”. I worked on it for about an hour and it all cleaned up nicely. I also removed all of the paper and tape I had in position to catch any overspray.
