Sanded down the bow and forward fairing again as well as the inside of the fairing behind the rollbar. Applied some additional micro on the inside and a couple of spots on the forward fairing. After this dried, I sanded down these areas. I cleaned up the dust, then taped off the area around the fairing. Also taped up the inside of the cockpit from the rollbar down—didn’t want any overspray on the inside of the windscreen or the panel. Next, I shot a couple coats of high build sanding primer on the fairing—inside the rollbar area and all of the outside. Next up some light sanding, probably some fill here & there and then I’ll start the pin hole dance.
