I finished up the aileron install today. Plenty of frustration getting all the washers installed—used a washer wrench for most of them. Also, hooked up the aileron control rods—more washers! Torqued the nuts and marked with torque seal. Next, I completed the installation of the AOA/pitot lines on the cockpit side-cut them to length and plugged them into fittings. I also installed the fuel vents lines. I am using a coiled vent system (see build log for 12-5-2015).
