Steve & Nancy Riffe
Date:  11-22-2016
Brief Description:  Baggage Door Strut
Yesterday, I received a door strut from McMaster Carr (part #11615A14). Matt Dralle has an excellent kit-log for installing the strut. The top bracket that attaches to the door rib is 11/32” from the edge of the door skin. On Matt’s lower bracket, he was 8” from the edge of the fuse skin—mine was actually 7.5”. I used three LP4-3 pop rivets to secure the top bracket, then I clamped the lower bracket in position at 8”, but my door would not fully close. A bit of trial and error, but I finally ended up a 7.5” and drilled #19 holes in the angle that runs across the back of the firewall. I used #8 screws and nuts to secure the lower bracket. You could install nut plates here, but I didn’t think it was worth the effort. I did loosen up the fit of the door just a bit—I was afraid I would twist off the key. It still requires pressure on the door to lock, and the fit is still good. Movin on to something else!
Drilled bracket to door rib
Attached lower bracket #8 screws
Strut holds door open
Copyright © 2001-2021 Matronics. All Rights Reserved.
