---I finished up squeezing the remaining rivets that attach the baggage door hinge to the forward top skin. I did it all with the pneumatic squeezer. In order to be able to remove the hinge pin, I filed the forward eyelet at a 45 degree angle and filed a small groove in the top skin. This is just enough to get the pin inserted and removed. Once the pin is in, I can rotate the leg under the edge of the skin which the baggage door seals against. There is no way the pin can come out when the door is closed.
