Steve & Nancy Riffe
Date:  6-14-2016
Number of Hours:  3.00
Brief Description:  EGT/CHT wires connected-R. side
Log 3 of 3. Trying to get finished up on the firewall forward stuff. I started with running 4 EMS sensor wires from where they exit the lower left firewall to the right side of the firewall. I removed several adel clamps and added the EMS wires as well as the RG400 cable for the GTN antenna which will mount under the top cowling. I ran and secured the EGT & CHT cables from the engine to a location on the right motor mount where they will connect to the EMS wires. I got everything secured and tie wrapped—looked all neat and purdy! Hmm, brain fade—I didn’t label the wires—dang it! The EMS wires are labeled “CHT #1, EGT #3 etc”. The wires from the engine are red & white and red & yellow—easy enough to tell the CHT from the EGT, but which cylinder?? I had to cut all the wire ties, and remove several adel clamps to trace the wires back to determine which cylinder went with which wire. I plan to NOT repeat this error on the left side. After I got over that setback, I stripped wires, crimped on connectors and plugged them together. I added some shirk tubing over the insulated spade connection and used self fusing silicone tape to enclose the bundle. Then, I went back and secured all off the tie wraps I had previously cut off. I’m calling the right side done—at least until something else pops up. Tomorrow, I’ll start this same process on the left side.
Adding terminals to EMS wires
Wires connected
Wires connected
Wies secured
Wies secured
