Went thru pretty much the same routine for the tension rods on the left side as previously done for the right. Lots of put them in place, remove, bend, re-install etc etc. I intended to slip some of the anti-chafe tubing over the outboard rod before I bend it, but somehow forgot. So, I slit it with the dremel, added to the rod and used some safety wire to secure, then a final install of the rod. Glad to be done with these little buggers! Next up is baffle seal material.
