Steve & Nancy Riffe
Date:  2-29-2016
Number of Hours:  3.00
Brief Description:  FAB snorkle fitting-1
I found the missing parts for the FAB mount—they were inside the K&N air filter box—which was still sealed. Appears that I didn’t inventory the FAB parts a year or so back. Per the instructions I cut a piece of plywood to 2 3/8” diameter. Well, that fit the injector body, but not the snorkel. I wrapped duct tape around the plywood plug leaving about 1/8” on the aft side free of tape. I fit this inside the hole saw used to cut the circle and forced the hole saw inside the snorkel. This left only about 3/16” of the plug sticking out, which fit just inside the injector body. I wiggled the snorkel around until it fit flush against the injector body and fit closely against the floor of the forward left ramp assembly. I clamped the snorkel to the injector body and drew a line around the snorkel from the aft side of the injector body and also drew a line around the other end on the floor of the ramp assembly. I shined a light from the back side of the injector to mark the lower bolt holes on the snorkel—couldn’t get a light on the upper holes. Removed the snorkel and the left forward ramp. I cut out the center of the ramp with my dremel using the lines as a guide. Also drilled out the 2 lower bolt holes on the snorkel to 1/4”—then test fit to the injector—fits fine. I’ll use the gasket to locate the upper holes.
Snorkle fit to ramp floor
Need to trim snorkle for flush fit
Snorkle temp bolted to injector
