Steve & Nancy Riffe
Date:  2-26-2016
Number of Hours:  1.00
Brief Description:  Cowling nose work-4
Post 1. I was going to wait to mix up some resin when I had other glass work, but I need to get the nose finished so I can separate the halves—working on baffles and need to temp install cowl. So, I built some “dams” from modeling clay to keep the resin/flox where I need to fill some low spots on a slanted area. I applied the mixture in these low areas—after the goop sets up, I’ll cut away the clay and sand the nose—again.
Clay
Clay "Dam" to hold resin in place
Opposite side clay
Opposite side clay "dam"
Copyright © 2001-2021 Matronics. All Rights Reserved.
