Post 1. I was going to wait to mix up some resin when I had other glass work, but I need to get the nose finished so I can separate the halves—working on baffles and need to temp install cowl. So, I built some “dams” from modeling clay to keep the resin/flox where I need to fill some low spots on a slanted area. I applied the mixture in these low areas—after the goop sets up, I’ll cut away the clay and sand the nose—again.
