Steve & Nancy Riffe
Date:  1-2-2016
Number of Hours:  1.00
Brief Description:  Rivet W-412 tip ribs
I used some #60 grit paper to scuff up the flange mating area of the modified W-412 tip rib, then mixed up a batch of resin with flox. I spread this mixture on the inside of the fiberglass tip and then clecoed in the tip ribs. I squeezed in 11 rivets on the right tip, followed by another 11 for the left tip. All done with the riveting on wing tips. In checking, I find there were 300+ rivets set in order to attach the tips using the hinge method. Tomorrow I’ll finish up with the glass strips to secure the NAV antenna.
Tip rib riveted to tip
Copyright © 2001-2021 Matronics. All Rights Reserved.
