Steve & Nancy Riffe
Date:  1-2-2016
Number of Hours:  1.00
Brief Description:  Rivet W-412 tip ribs
I used some #60 grit paper to scuff up the flange mating area of the modified W-412 tip rib, then mixed up a batch of resin with flox. I spread this mixture on the inside of the fiberglass tip and then clecoed in the tip ribs. I squeezed in 11 rivets on the right tip, followed by another 11 for the left tip. All done with the riveting on wing tips. In checking, I find there were 300+ rivets set in order to attach the tips using the hinge method. Tomorrow I’ll finish up with the glass strips to secure the NAV antenna.
Tip rib riveted to tip
