Brief Description: Drilled R. rear spar attachment
Today was a repeat of the prior day. I re-checked all measurements once again to make sure nothing on the right side had changed in the middle of the night—all still good. I followed the same procedure as on the left side, except I skipped the ¼” drill bit. Several other builders drilled the rear spar in only 3 drill bit steps. Anyhow, I did get a very nice tight hole that was perpendicular to the spar. This side went faster than the left—second time always does. I was so excited to get this done, that I only got a pic when everything was finished.
