More wing install pics. In the middle of the night (when I get to thinking) I started thinking that the lower right pin was very hard to get started. I imagined the pin hitting the spar as I gave it a few polite "smacks" with a rubber hammer. Then I began thinking "what if I dinged the spar". Well, that kept me up most of the night. This afternoon, I grabbed a couple of neighbors and pulled the right wing. I inspected around the hole and not a mark. Whew! Dodged a bullet on that one. Didn't take but 10 minutes to pull, inspect and re-install. My advise to anyone following this blog is to taper the pins for at least an inch or more in order to more easily get it started.
