I finished sanding the resin and shot a coat of sanding primer—it revealed a couple of spots that will need additional work. Then, I pulled the tape off of the fairing. Where the fairing meets the skin, the edge is really nice. Where the fairing meets the plexi—well, not great. The edge fractured in a number of places and also a couple of areas had a sliver of tape trapped under the edge—ARGG! Can’t believe how much time I’ve spent on this POS fairing not to have it look any better than it does. I think I’ll just let it set for awhile and do yard work instead. I need to think on what to do with the fairing edge on the plexi
