Steve & Nancy Riffe
Date:  6-7-2015
Number of Hours:  3.00
Brief Description:  More brake bleed prep, start upper cowl hinge
I had intentions of filling the brake lines today, but got a bit of late start, so I put it off until next session. I did get everything prepared for the actual filling. I gave up on the idea of using an oil can—probably need a higher quality can to make it work. I switched to a pump up sprayer. I cut the tip off of the wand and slipped on some clear tubing, which I safety wired. The end that connects to the bleed valve was causing me a concern. I found a metal clip at NAPA which seems to hold the tubing firmly in place on the bleed valve now. I had tried zip ties and safety wire, but wasn’t satisfied either would work when pressure from the pump was applied. I also found a water bottle to catch the overflow from the reservoir. Everything is now in place. I also worked on the top cowl hinge attachment. Much of the time spent was trying to figure out what the plans were trying to show me. Anyhow, I got the top short segment cut. Tomorrow (if brake bleeding goes ok), I hope to get the longer top segment cut and then drill them both to the firewall. I just keep finding more stuff that needs to be done before riveting on the top forward cowl.
Clip to secure hose to bleed valve
Bottle to catch brake fluid overflow
Begin cowl attachment
