I’m waiting on an order from Spruce with adel clamps and some fittings to connect the MAP sensor to the engine. So, while waiting for my favorite guy in brown to show up, I decided to get the engine ground cable installed. I bought a braided ground strap from B&C earlier. I drilled out a rivet on the firewall, then drilled the hole up to accept the stud on a forrest of ground tabs. I connected the other end of the ground strap to the ground block. I ran a piece of silicone tape around one of the engine mount tubes, then around the ground strap. Secured with a stainless clamp. After I finish adding all of the ground wires, think I’ll cut off the lower part of the forrest of tabs.
Ground strap connected to engine, secured to mount
