Brief Description: Alternator, control cable install-1
Today I test mounted the alternator, pretty easy stuff. I’ll have to remove it to safety wire the bolts that hold the bracket to the engine (don’t like safety wiring-rather work on fiberglass-and really really don’t like that!). So, I moved on to the control cables. I installed all three cables to see how they were going to be routed. Now I have to remove them and connect up them to the control levers in the cockpit. I also dug out the governor for the constant speed Hartzell. Looks like I’ll have to remove the back and re-orient to allow the control cable to attach. Oh wow, this will entail more safety wiring!
