No pics tonight—doesn’t look much different than last night. I sanded all of the lower fairings in addition to the front areas where I had added some micro to fill some low spots. After sanding, I blew all of the dust off with the air compressor—the blast of air revealed the dreaded pin holes! Tonight I mixed up a batch of resin and applied to the pin holes using a credit card to smooth it out. By the time I had done both sides and the front, it was tacky enough to apply a second coat. I began with a third coat, but only got started before the resin heated up and began to gel. After this cures, I’ll sand and apply some sanding primer.
