Sonnys Web Site
Date:  8-15-2008
Number of Hours:  27.50
Manual Reference:  SEC 8
Brief Description:  Horizontal Stabilizer Skeleton Assy
*Step 5- Except for those indicated in the figure, final-drill the 1/8" holes common to the HS_10002 Front Spar and the HS-1007 Front Spar Doubler using a #30 drill.
Match-Drill the four 3/16" holes common to the spar and spar doubler into the HS-1013Front Spar Caps with a 3/16" drill, then final-drill the holes with a #12 drill
*Clamp something flat to the bottom of the HS-1008-L and-R Front Spar Attachment Brackets to keep them square to each other, then match drill the eight holes of the spar and spar doubler into the attachment brackets with a #30 drill. Cleco a few of these holes, remove the original single cleco and final drill with the same drill
*Put both HS1001 Skins back in the cradles. Cleco all the HS-905 Nose ribs in place, then rivet them to the skins using the rivets shown on Page 8-14. figure 1.
DEBUR & CSK
DEBUR & CSK
Cleco Skealeton
Cleco Skealeton
Wooden fixturs,
Wooden fixturs,
