Sonnys Web Site
Date: 10-28-2008
Number of Hours: 9.00
Manual Reference: SEC 10
Brief Description: Tailcone skeleton & Skins
1. F-10006A, B, C, and D Bulkheads are clecoed along with F-1047 Fuselage Stiffeners which will rest against the skins as shown in Figure 3. (Leave the vinyl on the other side; it will make it easier to slide the stiffeners through the bulkheads and frames later) "I found this to be a non issue with the vinyl off
2. In the same manner as the F-1047C-R,D-R, and E-R Stiffeners on the F-1073-R Side Skin were located and match drilled, locate and match drill the F-1047C, D and E Stiffeners on the F-1073-L Side Skin. These stiffeners are now dedicated left parts.
3. Cleco the F-1014 aft Deck and the F-11B Stop/Doubler to the F-1011 Bulkhead, then cleco the aft end of the deck to the F-1012A & B Bulkheads as shown in the figure.
- Make sure the bend in the F-1032 Longerons is still located at the break in the F-1073 Side Skins, then clamp the longerons to the F-1014 Aft Deck and the side skins as shown in Figure 1 (Only one side is shown clamped). For proper alignment, the apex (corner) of the longerons must be clamped even with the edges of the skins over their entire length. They must also be clamped even with the side edges of the F-1014 Aft Deck. See section A-A in Figure 1.
