Chris and Karens RV-6A
Date:  6-23-2007
Number of Hours:  10.00
Brief Description:  Wing kit unpacking after *YEARS* in storage
Now that the tail surfaces are pretty much complete (are they ever?... still need lead counterbalance & tip installation), it is time to *FINALLY* unpack the wing components!
The large AL piece in the middle is the spar carry-through that came pre-drilled to match the pre-drilled (*NOT* PRE-BUILT, *NOT* PRE-ANODIZED, *NOT* PRE-Anything, execept drilled!).
This piece was damaged upon arrival in Michigan in 1996, I think... It was bent a bit and, considering how careful the instructions warn you to be with the holes in the spar components, I decided to send it back to Van's for replacement/repair. They bent it back in shape and returned it to me... I certainly hope this doesn't cause any spar-fuselage installation issues when that time comes!
Left elevator, trim servo access
Box moved to CA in 1997
Another shot, old pillows used for padding
