Brief Description: Preparing right wing components
Installed ADHARS bracket using the retrofit Skyview template. When I ordered the brackets I didn't realise you have to order the template, so there was a delay in installing them until the template arrived. It looks as though the template will be required for other Skyview modifications, as it's a very complex-looking template. I wondered if I should wait for the template and brackets before installing the top tailcone skin, to make the mod easier, but I was impatient to keep going so installed the top skin. Turns out it is easy to install the brackets on the completed tailcone.
Deburred, prepped and primed right wing tip parts, rear spar, bent wing tip tabs and hand hold. Prepped and primed all remaining wing ribs.
