P 27 - 05. Ran main brake lines and secured them to tunnel rib.
27 - 06. Installed reservoir brake lines.
P28-02. Installed fluid fitting onto fuel pump, and installed pump on bracket. This took a very long time. The slots in the flanges of the pump allow the unit to move laterally as you tighten up the attach bolts. The pump moved so much (It only takes a little) that it was impossible to get a socket or spanner onto the other bolt head. All very fiddly as you have to work in the confined space of the central tunnel. Not a fun job!
