Shirleys Web Site
Date:  9-28-2013
Number of Hours:  1.00
Manual Reference:  31
Brief Description:  Reed switches
Finally got both reed switches working. Switches needed to be higher, closer to underside of arm rest. We cut away the plastic from the adel clamp, and bent the clamp to bring the switch closer to the arm rest. The switch on the left side works when the pin is not fully engaged - I know it shouldn't so this will be a pre-flight checklist item unless we can fix it later.
