RV-7A Construction Log
RV-7A
Gear
4-2-2015
Main Gear Intersection Fairings 2
I removed the fairings, fastened the two halves of the wheel fairing together and glued on the interesection fairing.
However, I put electrical tape between the halves of the wheel fairing so they wouldn't get glued together.
I used normal Epoxy Resin with a little flux in it for glue.
Electrical tape on joint
Glued on fairing
Pretty good glue
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
