RV-7A Construction Log
Date:  4-2-2015
Brief Description:  Main Gear Intersection Fairings 2
I removed the fairings, fastened the two halves of the wheel fairing together and glued on the interesection fairing.
However, I put electrical tape between the halves of the wheel fairing so they wouldn't get glued together.
I used normal Epoxy Resin with a little flux in it for glue.
Electrical tape on joint
Glued on fairing
Glued on fairing
Pretty good glue
Pretty good glue
