I will put the sticks in next. I think this is the last time because once I start wiring I can't imagine taking them out. I looked at the aileron electric trim and realized I do not want to install it without first putting a connector on the wires.
I've decided to use D-sub connectors for most everything. I like the the way they pinch on with no soldering and I like the connector cases. I also like the pin connections.
So I put a 9 pin female connector on the trim motor.
