I removed the tape off the skin cause I don't need it and it will be in the way. I'll feather the fiberglass onto this area. I added a second layer of black tape to the tape line on the canopy.
I poured the thick fiberglass mix into a syring. I had to drill out the syring hole to 1/8 in order to push the goopy stuff out. It is thick as peanut butter. The guy at Fiberglass Supply told me I could make it as thick as I wanted with flock. I don't want it to be running down the sides and down under the plexiglass onto the glare shield.
I guess this layer of fiberglass with flock fills in the tight gap under the plexiglass canopy and starts to make the smooth surface for fiberglass glass to be layed.
