Brief Description: Final mating of canopy to frame 3
After I had the roll bar with screws in it, I did the side rails. You can see dimples at the screws and these are tightened only a little until contact of the metal and canopy is obtained. I'll have to smooth these dimples with fiberglass later.
I tightened these only until the nut and screws were close enough to take out all the gap between the frame and canopy. NOT TORQUED. I don't want to crack anything. And I plan to put a bead of silicon or pro-seal along the edge so I don't see a need to put a lot of force on tightening these screws.
