Brief Description: Fitting Rear Window 7: Tapped Roll Bar Holes
Window is all drilled. These holes will be enlarged and countersunk accordingly later.
After removing the window the roll bar holes were enlarged to #35. And these were then tapped for a 6X32 screw/bolt. I used BoeLube for tapping. Good stuff.
