Brief Description: Drilling the Canopy 8: Drill F-631 holes
I drilled the rib on the bench. Then I put the F-631 rib back on. Clamped the side rails and re-installed the canopy. I checked fit. I also checked hole locations, edge margins.
I'm wondering if the fit of the canopy in the front is right. Notice my canopy line as it goes thru the forward slot is slight raised, but almost parallel to grond. Other's seem to have it sloping up more at this point. Also notice the distance between the canopy bottom edge and the rivet holes. Others have more distance here.
I think mine is fine, and apparently is not critical because there is no guideline nor instructions for this fit.
