Brief Description: Fitting the Canopy Frame to the Fuselage 7
These canopy arcs are suppose to be flat. And you're suppose to be able to flute them until they are. So first I had to make sure I didn't flute where screws will go. Drawing calls out a certain spacing and plans say make sure the you know what screw spacing you'll use so you don't flute in the wrong place. Looks like I'll want the screws to fall inbetween the screws on the roll bar. So if I skip every other rivet, the screw spacing for the canopy will be 3 inches. I think that's okay.
