RV-7A Construction Log
RV-7A
Fuselage After Flip
1-25-2010
Push Rod for Elevators 6
The up stop and down stop work well. I get 30 degrees up motion and 23 down motion. The nuts at each end were tighten. This elevator push rod will get removed and stored till final assembly. I'll also prime the whole rod.
Down Stop 23 degrees
Up Stop 30 degrees
Push rod is done.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
