The bell crank get set to neutral which is suppose to be the upper and lower bolts in line with each other (whatever that means) or by placing a 3/8 socket over the lower bolt thru the access hole. I used this socket method to arrive at neutral.
I put in the push rod and screwed he bearings in to fit. The screwed in almost all the way, which is good, so this won't unscrew.
