Brief Description: Attach HS to Fuselage 12: Rear Spar
After finally getting the fron spar bolted on and the revised spacer made, it was time to finish the rear spar.
I put 3/16 spacer under the rear spar per plan and match drilled the four holes. I started with a smal bit and worked up to #12. Then put in the bolts.
Elevators are put back on in preparation of putting in the push rod.
