Brief Description: Attach HS to Fuselage 9: The fix
This fix is because my outside hole is not centered in the 5/8 part of the longeron. It is slightly inboard which means the edge margin on the longeron is only about 1/8 (maybe 3/16) but still I feel better with this triangle plate as a doubler for the longeron. This is where the horizontal stabilizer bolts on.
