Brief Description: Attach HS to Fuselage 6: Measure and square up
I measured and squared up the HS to the fuselage. I made sure it was centered. And using a diagnole measure I made sure it was straight with no sweep to the fuselage.
Then I started measuring and marking the hole locations. I decided to use the rivet lines on the longeron for the left right location. This turned out to not work so good. As you'll see my holes are a little inboard from where I really wanted them.
