Test fit cover. The cover wouldn't go into position. I finally found an interference. The brake lines hit the angles holding the fuel pump. Funny this is not mentioned in the plans or drawing from Andair.
I thought about re-routing the brake lines, but decided instead to just sand away a little material and create clearance for them in the angles.
