Brief Description: Attach HS to Fuselage 5: Set HS in place
I set the HS on the fuselage. Pretty cool. I put the shims under it as indicated on drawing. The shims raise it above the height of the Universal rivet heads.
But I had an interference I had to fix before I could go any farther. The vertical bars hit the HS skin. So I used a file and removed a little material on both bars.
