Brief Description: Tubing: Brake Lines 5: More tube routing
I went thru the top hole of the gear weldmount. And stayed forward of the fuel line. From the top view in photo 2 below you can see that maybe I should have gone aft of the fuel line, but at the time of routing it didn't feel like it.
Tubes have clearance from each other and later I think I'll tie them together with a spacer in between for vibration control.
