Brief Description: Tubing: Brake Lines 4: Left tube routing
With the fittings in place it was time to man handle the tubing and make a run.
I used only the flexible springie thing over the tube for bending. I ran the tub thru bushings bending as I go. I started near the fuel valve and routed back towards the fitting to the wheels, then ran the line forward to the firewall.
