Brief Description: Tubing: Brake Lines 3: More fittings
Finally I'm getting back to the brake lines.
I looked at the drawings and decided to work a few more of the end fittings I intalled the two elbows on the holder on the firewall. I installed the elbows in the cylinders. I used Fuel Lube on these because I don't plan to take them out.
I also tried inserting the brass fitting into the high pressure tube. This is suppose to be hard, but mine slipped right in, no problem.
