RV-7A Construction Log
Date:  12-29-2009
Number of Hours:  0.20
Brief Description:  Remove Wing 2: Summary of what I did
In summary, what I did with the wings attached included:
Rigging configuration of wing and drilling the hole in the aft spar
Cut the hole in fuselage for the flap push rod
Match drilled the bottom skin to the wing skin
and . . .
Drilled rear spar
Drilled rear spar
Cut hole for this push rod
Match drilled these holes
