Next are the break lines. I should take the wings off now, but some pilot friends are coming over tomorrow on New Years Day to see it. So I'll leave the wings on for them to see. But then I'm taking off the wings before I proceed with the brake lines.
I put the fitting on the bottom that goes out to the landing gear.
Then I decided to mount the brake fluid resevoir. Not sure why I didn't do this way back when I was working the firewall. Oh well. I made a template in order to drill the two holes because you can't put the resevoir up against the firewall to match drill due to the 1/2 inch protrusion where the fuel lines attach in.
